Hello! I'm having a big time issue with the ARCgis Javascript. For some reason, occasionally when I refresh the page, the map will not instantiate the Geocoder element or hide the layers after the defferred map is instantiated.
Here's the code:
require([
"dojo/parser", "dojo/ready", "dojo/dom-construct", "esri/config", "dojo/_base/connect",
"esri/Color", "dijit/layout/ContentPane", "esri/dijit/Geocoder",
"dojo/dom", "esri/map", "esri/urlUtils", "esri/arcgis/utils",
"esri/tasks/query", "esri/tasks/QueryTask", "esri/tasks/Geoprocessor", "esri/tasks/FeatureSet",
"esri/geometry/webMercatorUtils", "esri/geometry/Point", "esri/graphic","esri/geometry/Extent",
"esri/dijit/Legend", "esri/dijit/Scalebar", "dijit/TooltipDialog",
"esri/dijit/Popup", "esri/dijit/PopupTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/PictureMarkerSymbol",
"dojo/domReady!"
], function (
parser, ready, domConstruct, esriConfig, connect,
Color, ContentPane, Geocoder,
dom, Map, urlUtils, arcgisUtils,
Query, QueryTask, Geoprocessor, FeatureSet,
webMercatorUtils, Point, Graphic, Extent,
Legend, Scalebar, TooltipDialog,
Popup, PopupTemplate, SimpleMarkerSymbol, PictureMarkerSymbol
ready(function() {
window.Point = Point;
window.webMercatorUtils = webMercatorUtils;
window.Graphic = Graphic;
esriConfig.defaults.map.panDuration = 1;
esriConfig.defaults.map.panRate = 1;
esriConfig.defaults.map.zoomDuration = 100;
esriConfig.defaults.map.zoomRate = 1;
esriConfig.defaults.map.slider = {left: null, right: "30px", top: null, bottom:"30px", width: null, height: "200px" };
parser.parse();
window.ourQueryTask = new QueryTask("http://gis.dogis.org/arcgis/rest/services/Public_Works/Parking_Facilities/MapServer/1");
window.ourQuery = new Query();
window.ourQuery.returnGeometry = false;
window.ourQuery.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;
window.ourQuery.outFields = ["*"];
function mercator_to_lat_lon(mercX, mercY) {
var rMajor = 6378137;
var shift = Math.PI * rMajor;
var lon = mercX / shift * 180.0;
var lat = mercY / shift * 180.0;
lat = 180 / Math.PI * (2 * Math.atan(Math.exp(lat * Math.PI / 180.0)) - Math.PI / 2.0);
return { 'Lon': lon, 'Lat': lat };
var defferredMap = arcgisUtils.createMap("8e298b55535548f4bcba1adf160111b5", "map", {
mapOptions: {
basemap: "topo",
center: [-95.9406, 41.2600],
minZoom: 15,
smartNavigation: false,
navigationMode: 'classic',
zoom: 16,
maxZoom: 18,
slider: true,
force3DTransforms: false,
isScrollWheelZoom: false,
isShiftDoubleClickZoom: true,
isZoomSlider: true,
isPan: false,
showAttribution: false,
displayGraphicsOnPan: true,
logo: false,
defferredMap.then(function(response) {
window.map = response.map;
map.disableMapNavigation();
map.enableDoubleClickZoom();
map.enablePan();
var resizeTimer;
var legendLayers = arcgisUtils.getLegendLayers(response);
var legendDijit = new Legend({
map: map,
layerInfos: legendLayers
},"legend");
layers = legendLayers;
var custom_geocoder = {
placeholder: 'Filter by Venue',
var search_element = new Geocoder({
arcgisGeocoder: custom_geocoder,
autoComplete: true,
map: map
}, dom.byId("search"));
search_element.startup();
search_element.on("select", showLocation);
function showLocation(evt) {
map.graphics.clear();
var point = evt.result.feature.geometry;
var symbol = new PictureMarkerSymbol("<?php echo get_template_directory_uri(); ?>/assets/img/pin_all.svg", 32, 40)
var graphic = new Graphic(point, symbol);
map.graphics.add(graphic);
setTimeout(function() {
$('.checkbox:first', '#onstreet').click();
$('.find-me').on('click', function() {
$(this).addClass('searching');
if (navigator.geolocation) {
if (typeof geocoder !== "undefined") {
navigator.geolocation.getCurrentPosition(success_geo, errorFunction);
} else {
get_map_location();
$(".esriPopupWrapper").bind("DOMSubtreeModified", window.update_our_popup);
}, 3000)
}, function (error) {
alert("Error: ", error.code, " Message: ", error.message);
defferredMap.cancel();
map.on("load", function(theMap) {
$('#meters_all').click();
});Any ideas? I've completely rebuilt this 3 different times, really stuck here.
