Original User: wjacksonI'm starting to learn the Python Add-in starting with some simple code. This bit attempts to capture XY of mouse click event and write it to a point feature. The message box displays the XY but nothing else seems to be working. Can anyone show me what'sw wrong?import arcpy
from arcpy import env
import pythonaddins
class ToolClass2(object):
"""Implementation for ArcGISAddins_addin.tool (Tool)"""
message = "Your mouse clicked:"
def __init__(self):
self.enabled = True
self.shape = "NONE" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
def onMouseDownMap(self, x, y, button, shift):
message = "Your mouse clicked:" + str(x) + ", " + str(y)
pythonaddins.MessageBox(message, "My Coordinates")
env.outputCoordinateSystem = r"Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj"
point = arcpy.Point(x, y)
pointGeometry = arcpy.PointGeometry(point)
""" Create a copy of the PointGeometry objects, by using pointGeometry """
""" as input to the CopyFeatures tool. """
arcpy.CopyFeatures_management(pointGeometry, "c:/temp/test.gdb/points")
