ArcGIS Pro (latest)
Using the ExportToJPEG (or even ExportToPNG) arcpy function, I can't seem to export an image with my desired resolution. It always defaults to 96 dpi even when I specify 500. What am I doing wrong? Is this a bug?
p <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"project loaded"</SPAN><SPAN class="punctuation token">)</SPAN>
l <SPAN class="operator token">=</SPAN> p<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"MyLayout"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"layouts listed"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="operator token">not</SPAN> l<SPAN class="punctuation token">.</SPAN>mapSeries <SPAN class="keyword token">is</SPAN> None<SPAN class="punctuation token">:</SPAN>
ms <SPAN class="operator token">=</SPAN> l<SPAN class="punctuation token">.</SPAN>mapSeries
<SPAN class="keyword token">if</SPAN> ms<SPAN class="punctuation token">.</SPAN>enabled<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> pageNum <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> ms<SPAN class="punctuation token">.</SPAN>pageCount <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
ms<SPAN class="punctuation token">.</SPAN>currentPageNumber <SPAN class="operator token">=</SPAN> pageNum
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Exporting page {0} of {1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>currentPageNumber<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>pageCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
l<SPAN class="punctuation token">.</SPAN>exportToJPEG<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\\Users\\Theo\\Dropbox\\site_plans\\Current_GR_site_plans\\GR2-GroundMovement-SP-_{0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>currentPageNumber<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">".jpg"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">500</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>You can see at the end I specify 500 as the resolution. Even when I write- resolution = 500, it's the same. My images aren't coming out in my desired quality.
If I export a single page using the share ribbon, setting the dpi to 500, it works. But I'm automating this, so that's not a viable option for me.
Guides used:
MapFrame—ArcPy | ArcGIS Desktop
Layout—ArcPy | ArcGIS Desktop
similar issue to:
ExportToJpeg Resolution Problem
but i don't understand the answers given.
