I have just started experimenting with Operations Dashboard and really enjoy the interface.
I have a question regarding data display spanning multiple layers.
For example:
I have three layers (1 polygon and 2 points); one layer features 4 different polygons - call them "Boundary Areas A - D", another consists of a small number of point locations - call them "Sites", and the last one consists of a larger number of point locations - call them "Address Points". All point locations, with varying numbers, can be found within each of these polygon areas.
At present, I have set-up 2 summary widgets per each of the Boundary Areas. For instance, Boundary Area A has a count for the Sites in one widget and a count for the Address Points in another widget and so on through Boundary D.
I would like to have another widget displaying the result of a mathematical operation between each of these two windows...for instance...say there were 5 Sites and 200 Address Points for Boundary A...the operation would be the following...5/200 x 100 and the widget would display 2.5%.
Is it possible to perform such a calculation given that the calculated response spans two separate layers instead of all the information being contained within one layer?
Thank you.
Jeff
