I'm having cursor position issues now that I've added a navigation tool bar to my map. This affects not only the window drawn for map zoom, but identifed objects as well.
I've seen this post about popups being in the wrong position, and have attempted to parse before map initialization, but the problem persists. My cursor still traps the wrong position (low and left).
My map and tool bar are created like this (haven't included all modules, but this targets where the issue is) :
Map.js:
var baseMapLayerWorld;
var myLayer;
require([
"dojo/parser",
"dojo/on",
"esri/map",
"esri/toolbars/navigation",
"esri/dijit/Search",
"esri/dijit/Scalebar",
"dijit/Toolbar",
"dijit/form/Button",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/InfoTemplate",
"esri/geometry/Extent",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojox/layout/ExpandoPane",
"dijit/layout/AccordionContainer",
"dijit/layout/TabContainer",
"dojo/domReady!"
], function (parser, on, Map, Navigation, Search, Scalebar, Toolbar, Button, ArcGISTiledMapServiceLayer, DynamicMapServiceLayer, FeatureLayer, InfoTemplate, Extent) {
parser.parse();
baseMapLayerWorld = new DynamicMapServiceLayer("http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer");
myLayer = new DynamicMapServiceLayer("http://ourserver/arcgis/rest/services/COMMUNE/Public/MapServer");
var bounds = new Extent({
"xmin":-17012392,
"ymin":-2139604,
"xmax":-16498016,
"ymax":-1750718,
"spatialReference":{"wkid":102100}
window.myMap = new Map("map", {
extent: bounds,
logo: false
window.myMap.addLayers([baseMapLayerWorld,myLayer]);
var scalebar = new Scalebar({
map: window.myMap,
scalebarUnit: "metric",
attachTo: "top-right",
scalebarStyle: "line"
dojo.connect(window.myMap, "onExtentChange", showExtent);
var navToolbar;
navToolbar = new Navigation(window.myMap);
var zoomInButton = new Button({
label: "test button",
showLabel: false,
iconClass: "zoominIcon",
onClick: function () {
//alert("test button clicked")
navToolbar.activate(Navigation.ZOOM_IN);
}, "zoomin");
zoomInButton.startup();
var zoomOutButton = new Button({
showLabel: false,
iconClass: "zoomoutIcon",
navToolbar.activate(Navigation.ZOOM_OUT);
}, "zoomout");
zoomOutButton.startup();
var zoomFullExtButton = new Button({
showLabel: false,
iconClass: "zoomfullextIcon",
navToolbar.zoomToFullExtent();
}, "zoomfullext");
zoomFullExtButton.startup();
var zoomPreviousButton = new Button({
showLabel: false,
iconClass: "zoomprevIcon",
navToolbar.zoomToPrevExtent();
}, "zoomprev");
zoomPreviousButton.startup();
var zoomNextButton = new Button({
showLabel: false,
iconClass: "zoomnextIcon",
navToolbar.zoomToNextExtent();
}, "zoomnext");
zoomNextButton.startup();
var panButton = new Button({
showLabel: false,
iconClass: "panIcon",
navToolbar.activate(Navigation.PAN);
}, "pan");
panButton.startup();
var deactivateButton = new Button({
showLabel: false,
iconClass: "deactivateIcon",
navToolbar.deactivate();
}, "deactivate");
deactivateButton.startup();
on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
window.myMap.on("load", function(){
require([
"js/Search",
"js/Legend",
"js/Print",
"js/Identify",
], function() {});
function showExtent(extent) {
var s = "";
s = "XMin: "+ extent.xmin.toFixed(2) + " "
+"YMin: " + extent.ymin.toFixed(2) + " "
+"XMax: " + extent.xmax.toFixed(2) + " "
+"YMax: " + extent.ymax.toFixed(2);
//dojo.byId("info").innerHTML = s;
function extentHistoryChangeHandler () {
// registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
// registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
zoomPreviousButton.disabled = navToolbar.isFirstExtent();
zoomNextButton.disabled = navToolbar.isLastExtent();
});Map and toolbar were added to html page like this:
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow: hidden;width: 100%; height: 100%; margin: 0;">
<div id="navToolbar" data-dojo-type="dijit/Toolbar" style="background-color:#ffffff;">
<button type="button" id="zoomin"></button>
<button type="button" id="zoomout"></button>
<button type="button" id="zoomfullext"></button>
<button type="button" id="zoomprev"></button>
<button type="button" id="zoomnext"></button>
<button type="button" id="pan"></button>
<button type="button" id="deactivate"></button>
</div>
Dojo config like this directly on html page:
<script>
var dojoConfig = {
parseOnLoad: false,
async: true,
packages: [
"location": '/OurApp/agsjs' // for xdomain load
"location": '/OurApp/js'
</script>
