I have a text element that I can't seem to find. I'm using this support document: TextElement—ArcGIS Pro | Documentation I can find it if I use the the text Name (Text 37), but in my case I have a multitude of maps and Text 37 might have irrelevant text in another map. So, in short I need to find and replace the Text.
Here's the script I'm using but it doesn't change the Text. I think maybe it's because "Lawrence M. Walsh Will County Executive" is in two lines. Can anyone see what the issue may be?
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os
<SPAN class="comment token">#workspace folder</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> ws <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"pathto\TestFolder"</SPAN>
<SPAN class="comment token">#print the number of aprx files in the workspace folder</SPAN>
aprxlist <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFiles<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"*.aprx"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Currently {0} maps to be updated."</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>len<SPAN class="punctuation token">(</SPAN>aprxlist<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#list the aprxs of the workspace folder</SPAN>
<SPAN class="keyword token">for</SPAN> aprxname <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFiles<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"*.aprx"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"changing text: {}\t"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>aprxname<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN>ws <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> aprxname<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#replace title date that occurs in the document</SPAN>
<SPAN class="keyword token">for</SPAN> lyt <SPAN class="keyword token">in</SPAN> aprx<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> elm <SPAN class="keyword token">in</SPAN> lyt<SPAN class="punctuation token">.</SPAN>listElements<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'TEXT_ELEMENT'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> elm<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">==</SPAN> <SPAN class="string token">'Lawrence M. Walsh'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token">#text</SPAN>
elm<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Denise Winfrey'</SPAN> <SPAN class="comment token">#new text</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>elm<SPAN class="punctuation token">.</SPAN>text<SPAN class="punctuation token">)</SPAN>
aprx<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#do not include this delete statement inside the above loop or it will</SPAN>
<SPAN class="comment token">#delete the mxd object inside the loop. Make sure to dedent.</SPAN>
<SPAN class="keyword token">del</SPAN> aprx
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"----done----"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
