I am installing ArcGIS Server 10.8.0 (Linux version) on a Cento 7 OS server. We are publishing geoservices from ArcPro (I also use a script to publish these services from a service definition file). All our python code is 3.6 for the geoservices.
The problem is that I need to install python modules (suds-py3, cvxopt, lxml, sqlalchemy, ....). Is it possible to load up these modules on the ArcGIS Server for python? The documentation seems to say NO for Linux (should have read first!), and shows a way for windows.
I was hoping that I just misunderstood something and there is a way. Seems like a big issue if you can't add modules.
Also, I was told by a colleague that you can setup ArcMap to use python 3 for geoservices. I don't believe this is correct, could not find any documentation on this. Am I correct - I thought you had to go to ArcGIS Pro if you want to use Python3.
Thanks for any Help!
