There a mysterious user (admin??????) created inside Portal and it can't be remove. Is this normal or did something happen during upgrade process that require the account to be create?
Apologies, I mispoke and updated my initial comment. You can reindex the portal and it should go away.
You can delete that account. It's created to do some intermediary work during the upgrade and was leftover in the index as an oversight. Run a user reindex via the Portal Administrator Directory and that will get rid of the user.
Jonathan,
I used the portal admin account that was created during installation process to delete but got this error message "You do not have permission to access this resource." I check at the portal admin interface and the account "admin695930" does not exist there. Is there any other way to remove this unwanted account?
Thanks Jonathan that works.
Membros conectados podem postar, seguir atualizações e mais. Novo aqui? Registre uma conta gratuita.
