I am trying to do a select by location and then update the selected features, seems easy enough but i am see to get it figured out. Basically i want to update only the parcels that are within the City limits layer and update the 4 fields. I have tried different variations but i can't seem to get to work. I don't get any errors and also doesn't stop. I would appreciate any help.
Here is what i have.
import arcpy
from datetime import datetime as d
startTime = d.now()
start_time = time.time()
arcpy.env.workspace = "C:/Temp/blah.gdb"
fc1 = "C:/Temp/blah.gdb/Parcels"
CITY = "C:/Temp/blah.gdb/City_Limits"
with arcpy.da.UpdateCursor(fc1, ['field1','field2','field3', 'field4']) as cursor:
for row in cursor:
#Select all parcels within the city limits layer
arcpy.SelectLayerByLocation_management(fc1,"HAVE_THEIR_CENTER_IN", CITY)
result = arcpy.GetCount_management(fc1)
row [0] = "IN CITY"
row [1] = "IN CITY"
row [2] = "IN CITY"
row [3] = "IN CITY"
cursor.updateRow(row)
del row, cursor
print('Done')
try:
print ('(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')')
except Exception as e:
# If an error occurred, print line number and error message
import traceback, sys
tb = sys.exc_info()[2]
print ("Line %i" % tb.tb_lineno)
print (e.message)
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
