There's obviously something about these VectorTileLayers, that I just don't get...
In IE (I'm using IE 11), if I point to this URL:
http://bl.ocks.org/tsamaya/raw/f5b2405395522cd0cc65/b194ba0d4f2102777173b32c213772d2f785aebb/
The map and VectorTileLayer loads up and displays fine.
If I take the exact same HTML code (from "View source") and save it to a file on my server, when I try to load the HTML, I get a "layer not supported" error in the debugger because I set it to break on all exceptions. No message in the console; the map and vector layer just don't display.
I thought perhaps there was some cross-domain thing going on because the same HTML will work in Chrome and Firefox so I downloaded the JSON that the page references and saved it on my server as well. Still get the layer not supported error.
Is it possible there's a timing error in loading the modules that is exacerbated in IE with it's script loading mechanism somehow?
Obviously, this is just an example of a problem I'm having in my own application, but unless I can figure this out, we're not going to be able to use these VectorTileLayers in our apps, not matter how promising they might be.
Cheers,
jtm
