For the Statistics geoprocessor tool one of the parameters is the "statistics_fields". It calls for the fields you want to get statistics on as well as the type of statistic. In pyton, it looks like this (see 3rd param):arcpy.Statistics_analysis("futrds", "C:/output/output.gdb/stats", [["Shape_Length", "SUM"]], "NM")
My question is, how do I set up this parameter in .NET?Geoprocessor GP = new Geoprocessor(); Statistics stats = new Statistics(); stats.in_table = @C:\Temp\Test\myRight.shp; stats.out_table = @C:\Temp\test.dbf; stats.statistics_fields = "[['J_Fld','COUNT']]"; GP.Execute(stats, null);
I've tried sending it strings formatted in several different ways, an array like the one in python, and a IVariantArray with no luck.Thanks.
