I'm trying to call dojo 1.7 and ESRI 3.0. I'm unsure of where this is breaking but I've made a modified version of the "Rename Dojo Namespace" tutorial.If anyone sees the error the help would be great.Thanks,<!DOCTYPE HTML> <html lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Multiple Dojo Calls</title> <!-- Load Dojo 1.7 from Dojo --> <script src="http://ajax.googleapis.com/ajax/libs/dojo/1.7.1/dojo/dojo.js"> </script> <link rel="stylesheet" href="http://ajax.googleapis.com/ajax/libs/dojo/1.7.1/dijit/themes/claro/claro.css" media="screen"> <!-- Load 3.0f from ESRI --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript"> djConfig = { scopeMap: [ [ "dojo", "esriDojo" ], [ "dijit", "esriDijit" ], [ "dojox", "esriDojox" ] ] }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script> <script type="text/javascript"> //1.7 doesn't need a DJ config file setup so this section should kick off both pieces of dojo djConfig = dojo.config; esriDojo.require("esri.map"); esriDojo.require("esri.virtualearth.VETiledLayer"); require([ "dijit/layout/BorderContainer", "dijit/layout/ContentPane","dijit/layout/AccordionContainer", "dojo/parser", "dojo/domReady!", "dojox/layout/FloatingPane", ]); var veTileLayer; function init() { var map = new esri.Map("map"); //Creates the Virtual Earth layer to add to the map veTileLayer = new esri.virtualearth.VETiledLayer({ bingMapsKey: 'AimF6LphvVcbtQZOyiopeyQT8n-QOTukhwoRZwnzKL1MM0_B1Dfc7ppeKmyPByKp', mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_ROAD }); map.addLayer(veTileLayer); } dojo.addOnLoad(initDojo); esriDojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="appLayout" class="demoLayout" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design: 'headline'"> <div class="centerPanel" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region: 'center', splitter: true""> <div id="map"> <div data-dojo-type="dojox.layout.FloatingPane" id="dFloatingPane" title="Zoom-Bar" data-dojo-props="resizable:false, dockable:true" style="position:absolute;top:5;left:1;width:100px;height:300px;visibility:visible;"> This is the content of the pane! </div> </div> </div> <div class="edgePanel" style="max-height: px, min-height: 50px;" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region: 'top', splitter: true">Header content (top)</div> <div data-dojo-type="dijit.layout.AccordionContainer" style="width: 25%" data-dojo-props="region: 'left', splitter: true""> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'"> <ul> <li> sample title </li> <li> sample title </li> <li> sample title </li> <li> sample title </li> <li> sample title </li> <li> sample title </li> </ul> </div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Your Bookmarks', selected: true"> <ul> <li> <b>Sample Bookmark</b> </li> <li> <b>Sample Bookmark</b> </li> <li> <b>Sample Bookmark</b> </li> <li> <b>Sample Bookmark</b> </li> <li> <b>Sample Bookmark</b> </li> <li> <b>Sample Bookmark</b> </li> </ul> </div> </div> </div> </body> </html>
