Hi all,
I've got myself a tricky situation that I hope someone can help me out with. Explaining the problem is a bit tricky, but I'll do my best. Please note that I am certainly not GIS expert, so please do your best to explain any solution as simple and detailed as you can. I'm using ArcMAP.
What I'm trying to do is take points along a road network, and determine the population in a 1 mile radius. To do this I have created a points layer, and have found a polygon layer with a certain population in each polygon. The polygon's range in size from a few hundred square km's to a hundred square kilometers (Picture #1). The way I've done this so far is to create a 1 mile buffer around each point (Picture #2). Now in order to determine the population in each buffer zone, I need to know the population density in each population polygon (I have this calculated) as well as the area that each mile buffer includes. When I union these two layers, my result is a layer with population density and area for each buffer. From there I can easily determine the population in each buffer (picture #3). However, it starts to become very difficult to do this when the points get closer together, because the buffer zone's begin to overlap eachother. When I try to union the buffer and the population polygons, it looks at each buffer overlap as its own individual polygon (picture #4). So now instead of 2 records for my one point, I end up with 237 records for my point. Across my entire network, I have a couple hundred thousand points. My computer can't handle the hundreds of millions of overlaps this causes. Does anybody have a way I can avoid this? I tried to dissolve the buffer layer, but when I Union the dissolved buffer it goes back to looking at each overlap as its own polygon, and I still end up with 100 million records.
I'm not committed to using the union method I've explained using above, but any attempt to use other methods such as spatial join doesn't seem to provide the information I need in the new layer (such as the area of the various population polygons it contains). Hopefully I've managed to explain my problem well enough, and haven't made you all too bored to read this entire problem. Thanks in advance for any suggestions or advice! I'll answer any questions you throw at me as best I can.
Zach
