HiI've written a Pyhton script which lists all layers, layer with broken links & datasources of a Project. At the end all datasources & layers with broken links are removed and a copy of the mxd is saved.The trouble start if I have broken links to our former geoserver. When I run my script it removes those datasources properly. But to open the newly saved project takes ages, eventhough the datasource & layer is removed! So after 5 minutes it opens (if there was only one removed datasource). Now I can save it (ctrl+s) and then it opens with normal speed (<30 second).Do you have any solutions or tips for this problem?thanksfelixdef startAnalysis(inputMxd, destLogFile):
lyrName, lyrSavedName, brokenLayerName=r"Dataframe: Grouplayer\Layer; Datasource","\n\nSaved layer: ","\n\nBroken Links:"
mxd = arcpy.mapping.MapDocument(inputMxd)
for df in arcpy.mapping.ListDataFrames(mxd): # nacheinander alle Dataframes in Projekt verwenden
for lyr in arcpy.mapping.ListLayers(mxd, "", df): # nacheinander alle Layer in Dataframe verwenden
lyrName=lyrName + "\n" + df.name + ";" + lyr.longName
try:
lyrName=lyrName + ";" + lyr.dataSource # speichern des "Dataframes;(Grouplayer)/Layer"
if blnSaveLayer.get():
lyr.saveACopy(lyr.name)
lyrSavedName=lyrSavedName + "\n" + lyr.name
except:
pass
brokenList=arcpy.mapping.ListBrokenDataSources (df)
for brokenLyr in brokenList:
arcpy.mapping.RemoveLayer(df, brokenLyr)
try:
brokenLayerName=brokenLayerName + "\n" + df.name + brokenLyr.longName + "; " + brokenLyr.dataSource
except:
print "Error: " +brokenLyr
ouputMsg= lyrName + lyrSavedName + lyrNotSavedName + brokenLayerName
f = open(destLogFile, "w")
f.write(ouputMsg.encode("utf8"))
f.close()
mxd.saveACopy(os.path.splitext(inputMxd)[0]+"_WithoutBrokenLinks.mxd")
