Arcgis 10.1 / give a query, I order my column sequence in ascending order (eg 1-2-2.1-2.2-3-4-etc), I have to rename the same sequence (ie 1-2-3-4-5-6-7 etc.) please someone know the solution?
I tried the Autoicrement ()
rec = 0
final autoIncrement ():
global rec
PStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
rec = PStart
else:
rec = rec + pInterval
return rec
It performs randomly the rename column (for example the number 1 that must be the 1 becomes 180 uses OID)
Thank you so much
Michele
