hi guys,
I have developed a geoprocessing service with one parameter as imput (GPString).
The service works fine on REST way ,but i need to test it in SOAP way.
Is possible to test it with SOAP UI? I have try but i don't understand how to build the xml in SOAP UI for input parameter
The method is "Execute"
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">soapenv:</SPAN>Envelope</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>soapenv</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fschemas.xmlsoap.org%2Fsoap%2Fenvelope%2F" target="_blank">http://schemas.xmlsoap.org/soap/envelope/</A><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>ns</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.esri.com%2Fschemas%2FArcGIS%2F10.1" target="_blank">http://www.esri.com/schemas/ArcGIS/10.1</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">soapenv:</SPAN>Header</SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">soapenv:</SPAN>Body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ns:</SPAN>Execute</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ToolName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ToolName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Values</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!--Zero or more repetitions:--></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>GPValue</SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Values</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!--Optional:--></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Options</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>DensifyFeatures</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>DensifyFeatures</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TransportType</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TransportType</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>SpatialReference</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LeftLongitude</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LeftLongitude</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>VCSWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>VCSWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LatestVCSWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LatestVCSWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>SpatialReference</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Format</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Format</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>FormatProperties</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>PropertyArray</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>PropertySetProperty</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Key</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Key</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>?<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>PropertySetProperty</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>PropertyArray</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>FormatProperties</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Options</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>EnvironmentValues</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>EnvironmentValues</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ns:</SPAN>Execute</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">soapenv:</SPAN>Body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">soapenv:</SPAN>Envelope</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
My imput patrameter is call "json_string", how i can compile the xml into Values section to test the service in SOAP UI?
