I have been using the Aggregate polygons tool before without any problems, but now when I used it on a different dataset I couldn't get it to work. I got an error message saying "TIN internal process error". Does anyone know what this means? It is a quite big dataset, so I thought that it maybe was to big for the tool to process, hence I created partitions so that the tool could process small parts of the data at a time. Now I get the Aggregate to polygons tool to work, but even though I use the smallest feature count (500) when creating the partitions, I still have an area that is not calculated and in the partitions attribute table it says Error in the Status column for those partitions. Could there be something else that is wrong with the dataset? The dataset I am using is a merged product from two separate layers, and the tool is working when I use it on the separate layers.
