Is it possible to add a csv file (or Excel spreadsheet) that is saved on a Sharepoint team site to an ArcGIS Pro map? When I try to add the file in ArcGIS Pro by adding data from path, I get a message "Invalid Path - Failed to create layer from "Your URL Here"". I also tried to map a connection to the file in the catalog view, but I can't do that either. I'm not sure if I'm getting this error because something is wrong in my path or because it's not possible to add a file from Sharepoint (even though my URL is correct). I've tried searching GeoNet and other ESRI resources and I can find alot on using ArcGIS Maps for Sharepoint to map data in Sharepoint. But I want to use ArcGIS Pro to reference Sharepoint data - not use Sharepoint to map data.
