I've had a project running under Beta, using Qt5.3.2 on a Mac with the ArcGIS SDK, targeting iOS and Android. I upgraded and am now running
Qt5.4.1
ArcGIS V10.2.5 for iOS and Android
The project deploys for the iOS target just fine.
For the Android I get a "Duplicate Resources" error while generating the Android Package, specifically:
:mergeDebugResources
/Users/tsidevelopmentmac2/QtProjects/build-BVTest2-Android_for_armeabi_v7a_GCC_4_9_Qt_5_4_1-Debug/android-build/res/values/strings.xml: Error: Duplicate resources: /Users/tsidevelopmentmac2/QtProjects/build-BVTest2-Android_for_armeabi_v7a_GCC_4_9_Qt_5_4_1-Debug/android-build/res/values/strings.xml:string/ministro_not_found_msg, /Users/tsidevelopmentmac2/QtProjects/build-BVTest2-Android_for_armeabi_v7a_GCC_4_9_Qt_5_4_1-Debug/android-build/__qt5__android__files__/res/values/strings.xml:string/ministro_not_found_msg
:mergeDebugResources FAILED
FAILURE: Build failed with an exception.
It appears that strings.xml is duplicated in the following two folders:
.../res/values/strings.xml
.../__qt5__android__files__/res/values/strings.xml
Deleting one or the other doesn't help, as that they are generated earlier in the build process.
Does anybody in Redlands have an idea of what may be causing this, or how to resolve it?
Thanks!!
Chuck
