I have a map that I want the user to interface with.
Right now the below code works great but the map is ALWAYS active.
I need to be able to activate the clicks after a button is clicked.
Until the user clicks a button the viewright.on("click"...... is not enabled.
On page reload the button should have to be clicked again to register the clicks in the map
Any thoughts?
viewright<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
viewright<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Do a bunch of stuff</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
