I want to embed a chart I made with Flourish into a story map I am making with Map Journal Builder. The iframe I get from Flourish looks like this:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>iframe</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>https://public.flourish.studio/visualisation/506598/embed<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token">frameborder</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>0<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token">scrolling</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>no<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="attr-value token"><SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN><SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>600px<SPAN class="punctuation token">;</SPAN></SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>iframe</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="attr-value token"><SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>100%!<SPAN class="punctuation token">;</SPAN><SPAN class="property token">margin-top</SPAN><SPAN class="punctuation token">:</SPAN>4px!important<SPAN class="punctuation token">;</SPAN><SPAN class="property token">text-align</SPAN><SPAN class="punctuation token">:</SPAN>right!important<SPAN class="punctuation token">;</SPAN></SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>a</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>flourish-credit<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>https://public.flourish.studio/visualisation/506598/?utm_source<SPAN class="punctuation token">=</SPAN>embed&utm_campaign<SPAN class="punctuation token">=</SPAN>visualisation/506598<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token">target</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>_top<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="attr-value token"><SPAN class="property token">text-decoration</SPAN><SPAN class="punctuation token">:</SPAN>none!important</SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">alt</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>Made with Flourish<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>https://public.flourish.studio/resources/made_with_flourish.svg<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">='</SPAN><SPAN class="attr-value token"><SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>105px!important<SPAN class="punctuation token">;</SPAN><SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>16px!important<SPAN class="punctuation token">;</SPAN><SPAN class="property token">border</SPAN><SPAN class="punctuation token">:</SPAN>none!important<SPAN class="punctuation token">;</SPAN><SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN>0!important<SPAN class="punctuation token">;</SPAN></SPAN><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>a</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
As you see, below the <iframe> there is a <div> to show the credit.
When I add it to the story map (Main stage/embed code) I get this message: Embed code can only contain one "<iframe>"
I could just add the chart link (https://public.flourish.studio/visualisation/506598/embed) in the web page link field instead but then the credit doesn't show and it's required.
I have tried to tweak the code like, for example, adding the <div> part into the <iframe> using a property called srcdoc to no avail.
Any idea how I can solve this problem?
Thanks!
