I am just curious if any one has any ideas on how this may perform faster as some of these tables can get quite large and at the rate I am going it is not looking good: about 700 recs/hr1) I have an input .csv file that has four xy or lat lon points per record (Make a copy into gdb for joining to shapefile after conversion)2) Open and plot 4 points into a feature class3) Create Min bounding geometry for shapefile4) append to shapefile so all record geometries in the end are stored into one shapefile.5) join attributes from table in gdb back to shapefile by oids.Any input appreciated... originally this was an "ave" script and it is much faster so I am going to take a look at that next for ideas.Thanks!import sys, os, csv, datetime, time, string, traceback, arcpy from os.path import splitdrive scriptPath = sys.path[0] (drive,tail) = splitdrive(scriptPath) # arcpy environments and liscences from arcpy import env from arcpy.sa import * arcpy.CheckOutExtension("spatial") arcpy.CheckOutExtension("management") arcpy.env.overwriteOutput = True # Set the XY Domain to # xmin of -180 # ymin of -90 # xmax of 180 # ymax of 90 arcpy.env.XYDomain ="-180 -90 180 90" arcpy.SpatialReference= spRef = "D:/ArcGIS/Desktop10.0/Coordinate Systems/" +\ "Geographic Coordinate Systems/World/WGS 1984.prj" if __name__ == '__main__': ##Steps to create polygon shapefile from 4 or 2 points hm.... ## 1) get list of 4 points and store in an array by x,y print drive, tail arcpy.env.workspace = scriptPath outFolder = scriptPath gdb = os.path.join(scriptPath,"temp.gdb") pointFC = "sample1Test.shp" csvFile = os.path.join(scriptPath,'test.csv') #arcpy.CreateFeatureclass_management(outFolder, pointFC, "POINT", "","","","") #Input table to database arcpy.TableToTable_conversion(csvFile, gdb, "vegtable") fieldNames = ['"UL_LON"','"UL_LAT"','"LL_LON"','"LL_LAT"','"UR_LON"','"UR_LAT"','"LR_LON"','"LR_LAT"','"PHOTO_ID"'] print fieldNames[0] print csvFile inFile = open(csvFile, "r") #inFile = open("D:/CreateShape/temp.gdb/vegtable", "r") headerLine = inFile.readline() valueList = headerLine.strip().split(",") print valueList latIndex = valueList.index(fieldNames[0]) lonIndex = valueList.index(fieldNames[1]) llLatIndex = valueList.index(fieldNames[2]) llLonIndex = valueList.index(fieldNames[3]) urLatIndex = valueList.index(fieldNames[4]) urLonIndex = valueList.index(fieldNames[5]) lrLatIndex = valueList.index(fieldNames[6]) lrLonIndex = valueList.index(fieldNames[7]) photoId = fieldNames[8] feats = arcpy.ListFeatureClasses() try: for feat in feats: print feat arcpy.Delete_management(feat) arcpy.env.workspace = gdb for feat in feats: print feat arcpy.Delete_management(feat) except: print "Couldnt be deleted" #Read each line in the csv file starttime = time.time() localtime = time.asctime( time.localtime(time.time()) ) i = 0 #cursor = arcpy.InsertCursor(pointFC) for line in inFile.readlines(): #print line fields = line.split(",") #print fields[0] points = "points%s.shp" %(i) print points arcpy.CreateFeatureclass_management(outFolder, points, "POINT", "","","","") #arcpy.MakeFeatureLayer_management() cursor = arcpy.InsertCursor(points) field = line.split(",") ## 2) create points and append or merge points together in one feature class latValue = field[latIndex] lonValue = field[lonIndex] #print "first point: (%s,%s)" %(latValue,lonValue) point = arcpy.CreateObject("Point") point.X = latValue point.Y = lonValue feature = cursor.newRow() feature.shape = point cursor.insertRow(feature) lat2Val=field[llLatIndex] lon2Val = field[llLonIndex] #print "Second point: (%s)" %lat2Val,lon2Val point = arcpy.CreateObject("Point") point.X = lat2Val point.Y = lon2Val feature = cursor.newRow() feature.shape = point cursor.insertRow(feature) lat3Val=field[urLatIndex] lon3Val = field[urLonIndex] #print "Third point: (%s)" %lat3Val,lon3Val point = arcpy.CreateObject("Point") point.X = lat3Val point.Y = lon3Val feature = cursor.newRow() feature.shape = point cursor.insertRow(feature) lat4Val=field[lrLatIndex] lon4Val = field[lrLonIndex] #print "Fourth point: (%s)" %lat4Val,lon4Val point = arcpy.CreateObject("Point") point.X = lat4Val point.Y = lon4Val feature = cursor.newRow() feature.shape = point cursor.insertRow(feature) shpGdb = "%s/temp.gdb/box%s" %(scriptPath, i) allMerged = "%s/temp.gdb/merged2" %(scriptPath) ## 3) perfom minimum bounding box tool by rectangle
arcpy.MinimumBoundingGeometry_management(points,shpGdb,"RECTANGLE_BY_AREA", "ALL") #arcpy.AddField_management(shpGdb, str(photoId), "TEXT", "", "", 25) #expression = ("\"%s\"") %(field[0]) #arcpy.CalculateField_management(shpGdb, str(photoId), expression, "PYTHON") if i == 0: arcpy.CopyFeatures_management(shpGdb, allMerged) if i >0: try: arcpy.Append_management(shpGdb,allMerged) print "appended?" except: print arcpy.GetMessages() arcpy.Delete_management(shpGdb) arcpy.Delete_management(points) i+=1 #arcpy.AddJoin_management(allMerged,"OBJECTID","vegetable", "OBJECTID") arcpy.JoinField_management(allMerged, "OBJECTID", "vegtable", "OBJECTID") inFile.close() endtime = time.time() totaltime = endtime-starttime print "\nScript took " + str(totaltime/60) + " minutes to run"
