HiMy code below. I am having issues when i have added a dynamic map service to my code. When the map zooms into the x/y specified, i get a 404 error on the dynamic map service - http://sccw08ags/ArcGIS/rest/services/APILBSR/MapServer/export?dpi=96&transparent=true&format=png8&layers=show:0,1,2,5,6&bbox=349519.8477901956,328478.0609601219,353292.1522098044,330017.9390398781&bboxSR=null&imageSR=null&size=1901,776&f=image
stating that the bboxSR is invalid (i have noticed the imageSR is null aswell)When i then pan on the map, the dynamic service works an is visual on the map. - http://sccw08ags/ArcGIS/rest/services/APILBSR/MapServer/export?dpi=96&transparent=true&format=png8&layers=show:0,1,2,5,6&bbox=347974.0165735332,327450.1526543053,351746.32099314197,328990.03073406144&bboxSR=27700&imageSR=27700&size=1901,776&f=image
.It seems its something to do with when the map loads and it zooms to the location, the dynamic service does not seem to know the SR!I have tried to set it manually using imageParameters however this failed. Please any help with this as in kinda stuck at the moment.cheers<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>CRM Mapping Testing</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://sw08agsd/DEV/css/map_new.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar { padding: 20px 20px; } #map { padding:0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript" src="http://sccw08ags/DEV/js/jquery-1.3.2.min.js"></script> <script type="text/javascript" src="http://sw08agsd/DEV/js/identify.js"></script> <script type="text/javascript" src="http://sccw08ags/DEV/js/jquery.stylish-select.min.js"></script> <!-- jquery plugin --> <script type="text/javascript" src="http://sccw08ags/DEV/js/jquery/jquery.url.packed.js"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); // Required for identify dojo.require("esri.tasks.identify"); dojo.require("esri.layers.FeatureLayer"); dojo.require("dijit.Toolbar"); dojo.require("dijit.layout.TabContainer"); //old tab "identify" box dojo.require("dijit._Widget"); //additional parameters for editing widgets dojo.require("dojox.layout.TableContainer"); dojo.require("esri.arcgis.utils"); dojo.require("dijit.form.CheckBox"); dojo.require("dijit.layout.AccordionContainer"); </script> <script type="text/javascript"> var symbol; var map; var graphic; var mapLayers = []; //var visible = []; var layer7results, layer3results, layer4results, layer2results, layer0results, layer1results; var setSymbol, setSymbol1, setSymbol2, setSymbol3, setSymbol4, setSymbol5, setSymbol6; var highlight_id1 = [], highlight_id2 = [], highlight_id3 = [], highlight_id4 = [], highlight_id5 = [], highlight_id6 = []; function init() { var initExtent = new esri.geometry.Extent({ "xmin": 186819, "ymin": 230984, "xmax": 506529, "ymax": 407263, "spatialReference": { "wkid": 27700 } }); map = new esri.Map("map", { extent: initExtent }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://sccw08ags/ArcGIS/rest/services/CABackground_Greyscale/MapServer"); //var imageParameters = new esri.layers.ImageParameters(); //ImageParameters.imagespatialReference = new esri.SpatialReference({ wkid: 27700}); //imageParameters.imageSpatialReference = "27700"; //imageParameters.format = "png8"; //imageParameters.imageSpatialReference = new esri.SpatialReference({wkid:27700}); //console.log(imageParameters.imageSpatialReference); var lbsr = new esri.layers.ArcGISDynamicMapServiceLayer("http://sccw08ags/ArcGIS/rest/services/APILBSR/MapServer", { "opacity": 0.7 //"imageParameters": imageParameters }); map.addLayer(basemap); //console.log(map.geometry.Extent.spatialReference.wkid); //mapLayers.push(basemap); //mapLayers.push(lbsr); // When dojo has received notification that everything's been loaded, we'll run an "anonymous function" dojo.connect(map, 'onLoad', function () { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); var urlObject = esri.urlToObject(document.location.href); // Set our default position, zoom level and layerid's var x = 351406; var y = 329248; var zoomLevel = 8; var layers = [0,1,2,3,4,5,6,7,8,9]; // Do we have a qeury string on the URL? if (urlObject.query) { // Do we have a coords parameter? if (urlObject.query.coords) { var coords = urlObject.query.coords.split(','); // We have an x and a y right? if (coords.length == 2) { x = parseFloat(coords[0]); y = parseFloat(coords[1]); console.log(x); console.log(y); } } // Let's check for a zoomlevel if (urlObject.query.zoomLevel) { zoomLevel = parseInt(urlObject.query.zoomLevel); console.log(zoomLevel); } //Let's check if any layers are specified if (urlObject.query.layers) { //layers = parseInt(urlObject.query.layers); layers = urlObject.query.layers.split(','); console.log(layers); } //set the visable layers that where passed in the url lbsr.setVisibleLayers(layers); } // Position our mapto the x and y provided in the url var point = esri.geometry.Point(new esri.geometry.Point(x, y)); map.centerAndZoom(point, zoomLevel); // Highlight the item on our map if (!graphic) { addGraphic(point); } else { graphic.setGeometry(point); } map.centerAt(point); setUpIdentify(layers); }); //adds an image to the x and y that was passed function addGraphic(point) { var symbol = new esri.symbol.PictureMarkerSymbol('http://sw08agsd/DEV/img/marker-icon.png', 20, 30); graphic = new esri.Graphic(point, symbol); map.graphics.add(graphic); } map.addLayer(lbsr); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <span id="layer_list"></span> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"></div> </div> <div id="tabs" dojoType="dijit.layout.AccordionContainer"> <div id="layer7Tab" dojoType="dijit.layout.ContentPane"></div> <div id="layer2Tab" dojoType="dijit.layout.ContentPane"></div> <div id="layer1Tab" dojoType="dijit.layout.ContentPane"></div> <div id="layer3Tab" dojoType="dijit.layout.ContentPane"></div> <div id="layer4Tab" dojoType="dijit.layout.ContentPane"></div> <div id="layer0Tab" dojoType="dijit.layout.ContentPane"></div> </div> </body> </html>
