I am using ArcGIS api JS with a layer of polygons. When I click on one polygon, it creates a layer of points that intersect the polygon clicked. When I then click on a point, the point gets highlighted correctly.
The problem is that once I have clicked at least once on a point and got it highlighted, if I then click on a polygon or anywhere else on the map where there is no polygons, this error occurs:
Uncaught (in promise) TypeError: Cannot read property 'setHighlight' of null
at d.f._updateHighlight (mapViewDeps.js:773)
at d.f.removeHighlight (mapViewDeps.js:773)
at Object.remove (GraphicsLayerView2D.js:7)
at d.c.remove ((index):751)
at d.<anonymous> ((index):2352)
at g ((index):38)
at Object.next ((index):37)
at (index):37
at new Promise (<anonymous>)
at Object.f [as __awaiter] ((index):36)
And when I then click again on a point, the point doesnt highlight anymore. But the popup works fine. One the highlight is not working.
I would like to know where is the poperty "setHighlight" and how can I avoid the issue?
If only I was able to pin point where the property is, I could probably undesrtand what is happening. But there is no info online about this property nor the issue.
So thank you for any of your help, it is really appreciated!
Julien
