I am able to create the Legend using the Legend Dijit in ArcGIS JavaScript API 3.21, but the layers that are set to visible won't display in the legend until I zoom in or zoom out or turn on another layer. What causes this? Note: the LegendDiv is assigned a value of "No Legend" from the Legend Dijit when the page first loads, rather than any layers.
In the map services, none of the layers are turned on. In the JavaScript, I set some of the layers to visible. I have even checked that the layers are indeed visible by the time the legend is being built.
I have three map services so I set up the legend like this (partial code):
var pointsLayer = new esri.layers.ArcGISDynamicMapServiceLayer(pointsURL, {
visible: true
var linesLayer = new esri.layers.ArcGISDynamicMapServiceLayer(linesURL, {
visible: true
var polygonsLayer = new esri.layers.ArcGISDynamicMapServiceLayer(polygonsURL, {
visible: true
map = new Map("map", {
extent: customExtentAndSR
//home button
var home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
//scalebar
var scalebar = new Scalebar({
map: map
map.on("load", function () {
toolbar = new Draw(map);
toolbar.on("draw-end", addToMap);
//toolbar.on("draw-complete", addMeas);
editToolbar = new Edit(map);
pointsLayer.setVisibleLayers([myPointsArray]);
linesLayer.setVisibleLayers([myLinesArray]);
polygonsLayer.setVisibleLayers([myPolygonsArray]);
map.on("click", function (evt) {
editToolbar.deactivate();
createMapMenu();
createGraphicsMenu();
map.reposition();
map.resize();
buildLayerList();
firstPrint();
// set up identify task click event
connects = on(map, "click", executeIdentifyTask);
map.on("layers-add-result", function () {
// test to see if sub-layers have been set as visible
for (var j = 0; j < map.layerIds.length; j++) {
var layer = map.getLayer(map.layerIds);
alert(layer.id + ' ' + layer.opacity + ' ' + layer.visible + ' ' + layer.visibleLayers);
// add legend
legendDijit = new Legend({
map: map,
layerInfos: [{
layer: polygonsLayer,
hideLayers: [indexPoly_CountyBdry, indexPoly_MuniBdry],
title: " ",
respectCurrentMapScale: true
layer: linesLayer,
hideLayers: [indexLine_PriorityArray],
title: " ",
layer: pointsLayer,
hideLayers: [indexPoint_ControlPts, indexPoint_FiberPts, indexPoint_ReferencePts, indexPoint_SchoolBusStopsOSPI],
title: " ",
}, "legendDiv");
legendDijit.startup();
map.addLayers([aerialLayer, aerialLayerZoom, tilesLayer, polygonsLayer, linesLayer, pointsLayer]);
