I'm trying to run a Python script to merge all polygon features in a single file geodatabase but my ListFeatureClasses function doesn't appear to be returning any FC names!
See attached with screen shots and code
import arcpy
import os
# This will be the list of polygon features to merge
listFC = []
# Set the workspace to state CoreLogic FGDB
arcpy.env.workspace = r"L:\SRS_Heirs_29Mar19\20190310_R8_HeirsProperty_AL_CoreLogicParcelsMods_SRS4952.gdb"
# Set output FGDB
outputFGDB = r"D:\Documents\ArcGIS\Projects\SRS4952_Heirs\SRS4952_Heirs.gdb"
# Set output FGDB and new merged FC
mergedFC = os.path.join(outputFGDB, "CL_AL_ParcelsArea")
# Get list of polygon feature classes in FGDB
listFC = arcpy.ListFeatureClasses(feature_type='Polygon')
# Now merge
print ("Starting merge now...")
arcpy.Merge_management(inputs=listFC, output=mergedFC)
print("Finished polygon merge...")
ListFeatureClasses is not returning any polygon feature classes (there are about 100 in the FGDB)
All polygon features have the same data schema
