I am referencing this popup example. Although it shows it consuming an ArcGIS online web map. I want to access my Feature Service. I modified the code to include my Feature Service https://developers.arcgis.com/javascript/jssamples/popup_sidepanel.htmlThe FS shown in code below is not the actual Service...just a junk URL1. with out the Online Web Map how do I modify this to get the code to run initializeSidebar(window.map); I tried this: map.on("load", initializeSidebar);HTML
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width:700px; height:400px;">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:false"
region="left" style="width: 30%;height:100%;">
<div id="leftPane" data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'"></div>
<div id="header2" data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'top'">
<div id="featureCount" style="margin-bottom:5px;">Click to select feature(s)</div>
<div id="pager" style="display:none;">
<a href='javascript:void(0);' id ="previous" class='nav' style="text-decoration: none;">
< Prev
</a>
<a href='javascript:void(0);' id="next" class='nav' style="text-decoration: none;">
Next >
</a>
</div>
</div>
</div>
<div id="mapDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
JS
var map;
require([
"dojo/ready", "dojo/on","dojo/_base/connect", "dojo/dom","dijit/registry","dojo/dom-construct","dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "esri/map","esri/arcgis/utils","esri/domUtils","esri/dijit/Popup"
], function(
ready, on, connect,dom,registry,domConstruct,parser,
BorderContainer, ContentPane,Map,arcgisUtils,domUtils,Popup
ready(function(){
parser.parse();
//setup event handlers for the next/previous buttons
on(dom.byId("previous"), "click", selectPrevious);
on(dom.byId("next"), "click", selectNext);
map = new Map("mapDiv", {
basemap: "topo",
center: [-77.4329, 37.5410],
zoom: 7,
slider: true
var featureLayer2 = new FeatureLayer("https://web1/arcgis/rest/services/Warbler_Map/Warbler_Map_Readonly/FeatureServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ['*']
map.addLayer(featureLayer2);
function initializeSidebar(map){
var popup = map.infoWindow;
//when the selection changes update the side panel to display the popup info for the
//currently selected feature.
connect.connect(popup, "onSelectionChange", function(){
displayPopupContent(popup.getSelectedFeature());
//when the selection is cleared remove the popup content from the side panel.
connect.connect(popup, "onClearFeatures", function(){
//dom.byId replaces dojo.byId
dom.byId("featureCount").innerHTML = "Click to select feature(s)";
//registry.byId replaces dijit.byId
registry.byId("leftPane").set("content", "");
domUtils.hide(dom.byId("pager"));
//When features are associated with the map's info window update the sidebar with the new content.
connect.connect(popup, "onSetFeatures", function(){
dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected";
//enable navigation if more than one feature is selected
popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager"));
function displayPopupContent(feature){
if(feature){
var content = feature.getContent();
registry.byId("leftPane").set("content", content);
function selectPrevious(){
window.map.infoWindow.selectPrevious();
function selectNext(){
window.map.infoWindow.selectNext();
