In the following script an Error Code 000964 keeps coming up. Any help on this would be great.
<SPAN class="keyword token">import</SPAN> arcpy
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/TEST_LINES.gdb/"</SPAN>
outbufferpath <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/TEST_BUFFER.gdb/"</SPAN>
outrasterpath <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/TEST_RASTERCLIP.gdb/"</SPAN>
outrastertopoint <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/TEST_RASTERTOPOINT.gdb/"</SPAN>
raster <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/STLM_NSP.gdb/MN_DEM3second"</SPAN>
featureClassList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> outbufferpath
<SPAN class="keyword token">for</SPAN> featureClass <SPAN class="keyword token">in</SPAN> featureClassList<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
coords <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"row[0].extent.XMin&"</SPAN> <SPAN class="string token">"& row[0].extent.YMin&"</SPAN> <SPAN class="string token">"& row[0].extent.XMax&"</SPAN> <SPAN class="string token">"& row[0].extent.YMax"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>Clip<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> coords<SPAN class="punctuation token">,</SPAN> outrasterpath <SPAN class="operator token">+</SPAN> featureClass<SPAN class="punctuation token">,</SPAN> featureClass<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"255"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ClippingGeometry"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MAINTAIN_EXTENT"</SPAN><SPAN class="punctuation token">)</SPAN>
Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
File <SPAN class="string token">"<string>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">15215</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> Clip
<SPAN class="keyword token">raise</SPAN> e
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">15212</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> Clip
retval <SPAN class="operator token">=</SPAN> convertArcObjectToPythonObject<SPAN class="punctuation token">(</SPAN>gp<SPAN class="punctuation token">.</SPAN>Clip_management<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>gp_fixargs<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>in_raster<SPAN class="punctuation token">,</SPAN> rectangle<SPAN class="punctuation token">,</SPAN> out_raster<SPAN class="punctuation token">,</SPAN> in_template_dataset<SPAN class="punctuation token">,</SPAN> nodata_value<SPAN class="punctuation token">,</SPAN> clipping_geometry<SPAN class="punctuation token">,</SPAN> maintain_clipping_extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">496</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="keyword token">lambda</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">lambda</SPAN> <SPAN class="operator token">*</SPAN>args<SPAN class="punctuation token">:</SPAN> val<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>gp_fixargs<SPAN class="punctuation token">(</SPAN>args<SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcgisscripting<SPAN class="punctuation token">.</SPAN>ExecuteError<SPAN class="punctuation token">:</SPAN> ERROR <SPAN class="number token">000964</SPAN><SPAN class="punctuation token">:</SPAN> Specified extent <SPAN class="keyword token">is</SPAN> invalid
Failed to execute <SPAN class="punctuation token">(</SPAN>Clip<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
NOTE: Line 8 was not intended. Also, not sure an ampersand (&) needs to be placed after .YMAX
THANKS to anyone who can uncover the problem.
