Here's just a quick post sharing my experience web editing.In the past weeks, I�??ve noticed people looking through support channels for a deeper discussion on web editing with Silverlight. A few people I talked to wanted more details on how to edit features from the code behind. So to that end, I did research and came up with some editing code.In the code, I use the FeatureLayer's graphics property to add features (graphics) to the Feature Service. My no frills customization is that I add an �??Insert Failed!�?� or �??Successfully Saved!�?� message. This message is triggered using the SaveEditsFailed and EndSaveEdits events respectively. I did it because I like success or failed messages. I also used the Silverlight�??s System.Windows.Threading.DispatcherTimer() object to clear these messages from the page after 5 seconds. Just to note, I did not use the Editor class for this use case.When planning for new tools, it�??s important to consider carefully when it�??s worth investing time and effort to develop a tool that performs custom editing on FeatureLayer in the code behind. This is because the API comes with efficient methods to do editing using the Editor Class. The Editor Class makes it possible to Add, Delete, and EditVertices straight from the XAML, plus more. In review, I counted the lines of code necessary to implement an �??Add�?� using the Editor class and then compared it to my code written below that works directly with FeatureLayer. For those who�??ve done this type of analysis, "Add" (for the most part) only involves adding the Editor resource to the XAML and adding the proper CommandParameter to a button or a hyperlink. From my research, it�??s clear that custom editing using FeatureLayer members takes a lot more coding. So before embarking on a custom editing job, be sure to understand the requirements and check to see that the wheel has not already been invented somewhere else in the API. If anyone has comments or other implementations, please share. -XAML-
<UserControl x:Class="SDK_Custom_Editing.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
<Grid x:Name="LayoutRoot" Background="White">
<Grid.Resources>
<esri:SimpleLineSymbol x:Key="DrawLineSymbol" Color="Green" Width="4" />
<esri:SimpleFillSymbol x:Key="DrawFillSymbol" Fill="#3300FF00" BorderBrush="Green" BorderThickness="2" />
<esri:SimpleMarkerSymbol x:Key="DefaultMarkerSymbol" Color="Red" Size="12" Style="Circle" />
<esri:SimpleLineSymbol x:Key="DefaultLineSymbol" Color="Red" Width="4" />
<esri:SimpleFillSymbol x:Key="DefaultFillSymbol" Fill="#33FF0000" BorderBrush="Red" BorderThickness="2" />
</Grid.Resources>
<esri:Map Extent="-13054165,3850112,-13027133,3863559" MouseMove="SanDeigoMap_MouseMove" x:Name="SanDeigoMap">
<esri:Map.Layers>
<esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" x:Name="Tiled"/>
<esri:FeatureLayer x:Name="EditLayer" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/0" AutoSave="False" Mode="OnDemand"/>
<esri:GraphicsLayer x:Name="GraphicsLayer" />
</esri:Map.Layers>
</esri:Map>
<Canvas HorizontalAlignment="Left" VerticalAlignment="Top" Margin="0,0,0,0">
<StackPanel Orientation="Horizontal" Margin="10,10,10,10">
<esri:Toolbar x:Name="MyToolbar" VerticalAlignment="Top" HorizontalAlignment="Left"
ToolbarItemClicked="MyToolbar_ToolbarItemClicked">
<esri:Toolbar.Items>
<esri:ToolbarItemCollection>
<esri:ToolbarItem>
<esri:ToolbarItem.Content>
<Canvas>
<Border BorderBrush="Black" BorderThickness="1" Background="LightGray" Margin="2" CornerRadius="5">
<TextBlock x:Name="insert" Text="Insert" HorizontalAlignment="Center" VerticalAlignment="Center" Margin="4,4,4,4" FontSize="16" Foreground="Black" FontStyle="Italic"/>
</Border>
</Canvas>
</esri:ToolbarItem.Content>
</esri:ToolbarItem>
</esri:ToolbarItemCollection>
</esri:Toolbar.Items>
</esri:Toolbar>
</StackPanel>
</Canvas>
<StackPanel VerticalAlignment="Bottom" Margin="10,10,0,0" >
<TextBlock Text="{Binding StatusTextMessage}" x:Name="StatusTextMessage" HorizontalAlignment="Left" VerticalAlignment="Center" TextWrapping="Wrap" FontWeight="Bold" Margin="0,0,10,0" />
<TextBlock x:Name="MapCoordsTextBlock" HorizontalAlignment="Left" VerticalAlignment="Center" Text="Map Coords: " TextWrapping="Wrap" FontWeight="Bold" />
</StackPanel>
</Grid>
</UserControl>
-Code Behind C#-
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using System.Windows.Browser;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Symbols;
namespace SDK_Custom_Editing
public partial class MainPage : UserControl
private TextBlock _textmessage;
private Symbol _activeSymbol = null;
private Draw draw { get; set; }
private FeatureLayer featurelayer { get; set; }
private System.Windows.Threading.DispatcherTimer timer { get; set; }
public MainPage()
InitializeComponent();
draw = new Draw(SanDeigoMap)
LineSymbol = LayoutRoot.Resources["DrawLineSymbol"] as LineSymbol,
FillSymbol = LayoutRoot.Resources["DrawFillSymbol"] as FillSymbol
draw.DrawComplete += Draw_DrawComplete;
_textmessage = StatusTextMessage;
private void SanDeigoMap_MouseMove(object sender, MouseEventArgs e)
try
System.Windows.Point screenPoint = e.GetPosition(SanDeigoMap);
if (SanDeigoMap.Extent != null)
MapPoint mapPoint = SanDeigoMap.ScreenToMap(screenPoint);
MapCoordsTextBlock.Text = string.Format("Map Coords: X = {0}, Y = {1}",
Math.Round(mapPoint.X, 4), Math.Round(mapPoint.Y, 4));
catch (Exception ex)
String mes = ex.ToString();
private void MyToolbar_ToolbarItemClicked(object sender, ESRI.ArcGIS.Client.Toolkit.SelectedToolbarItemArgs e)
featurelayer = SanDeigoMap.Layers[1] as FeatureLayer;
switch (e.Index)
case 0: // First esri toolbar item in toolbar
draw.DrawMode = DrawMode.Point;
_activeSymbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as Symbol;
break;
case 1:
break;
default:
break;
draw.IsEnabled = (draw.DrawMode != DrawMode.None);
private void Draw_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args)
draw.IsEnabled = (draw.DrawMode == DrawMode.None); // Draw one at a time
featurelayer.EndSaveEdits += Insert_EndSaveEdits;
featurelayer.SaveEditsFailed += Insert_SaveEditsFailed;
ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
Geometry = args.Geometry,
Symbol = _activeSymbol,
featurelayer.Graphics.Add(graphic);
featurelayer.SaveEdits();
timer = new System.Windows.Threading.DispatcherTimer();
timer.Interval = new TimeSpan(0, 0, 0, 5, 0); // 5 seconds
timer.Tick += new EventHandler(Insert_TimedMessageEnd);
timer.Start();
public void Insert_SaveEditsFailed(object sender, EventArgs e)
string mes = e.ToString(); // For debugging
_textmessage.Text = "Insert Failed!";
public void Insert_EndSaveEdits(object sender, EventArgs e)
_textmessage.Text = "Successfully Saved!";
public void Insert_TimedMessageEnd(object o, EventArgs sender)
_textmessage.Text = "";
timer.Stop();
Regards, Doug Carroll, ESRI Support Services SDK Team http://support.esri.com/
