In the JS API 3.17, I am using the Directions widget for routing. After getting directions, I am saving the stops to a SQL Server database in JSON format as returned in the directions. I can load the first two stops to the directions widget by calling updateStop(...). If I've got more than 2 stops, then calling addStop(...) will add another stop in the widget. What I cannot figure out is how to load a start and end point (two stops in the directions widget) AND a waypoint, then allow the directions widget to recalculate directions via a call to getDirections(). The waypoint is not a stop-over point. It's just the location to pass through. I found that the feature property in each stop has an attribute for "isWaypoint". I have tried checking each stop and if isWaypoint==true, then do not add the stop to the directions widget. However, the call to network analyst Route/solve should still have the waypoint(s) so the route is calculated through those points. I'm really just trying to replicate a route with waypoints programmatically. Below is some code I've been playing with to load the stops from the database. routeData is my own Object with properties that I fill from the database. The StopsJson property has the JSON for each exactly as found in the directions widget. Anyone done this or have any advice? If I have not been clear, please comment below and I can elaborate.
loadStops: function (routeData) {
if (routeData != null &&
routeData.Stops != null &&
routeData.Stops.length > 0) {
var stops = JSON.parse(routeData.StopsJson);
if (stops == null) {
return;
var numStops = stops.length;
var comments = routeData.Comments.join(". ");
var numWaypoints = 0;
var insertionIndex = 0;
// NOTE: do we call Route?solve directly?
//this.map.directions.stops = stops;
for (var index = 0; index < numStops; index++) {
var stop = stops[index];
var point = new Point(stop.feature.geometry);
if (stop.feature.attributes.isWaypoint) { //(stop.name != "DWWP") {
// This is a waypoint
//insertionIndex = index;
numWaypoints++;
// The following line adds the stop (as waypoint) but DOESN'T WORK with directions widget
//this.map.directions.stops.splice(insertionIndex, 0, stop);
else {
insertionIndex = index - numWaypoints;
if (insertionIndex < 2) {
this.map.directions.updateStop(point, insertionIndex);
else {
this.map.directions.addStop(point, insertionIndex);
