I need to use the results of a geoprocessing workflow in a separate GP workflow calculation. I ran a TABLE_SELECT to create a table containing the required input values from the first GP model (top line of image below). I then wanted to use the GET_FIELD_VALUE function to extract the required value from the table and use this value in the CALCULATE_FIELD function of the second GP model (second line of image below). However, it does not "see" the field to be able include it in the calculation expression. I cannot find a way to do this this. Any ideas? Thanks very much.
