Hello,I am facing problem migrating this function from VBA to vb.net. I do appreciate your help. I am using 10.1 and vs2010
Public Function GenerateClassBreaks(pFeatLayer As IFeatureLayer, sValFieldName As String, lNClass As Long, sClassification As String) As Variant
' classifies data using IClassify2 and Quantile classification,
' then creates ClassBreaksRenderer using these breaks,
' and assigns to first layer in the map
On Error GoTo ErrorHandler
Dim pFClass As IFeatureClass
Dim pFeature As IFeature
Dim pFCursor As IFeatureCursor
Dim pTable As ITable
Dim pClassifyGEN As IClassifyGEN
Dim pTableHistogram As ITableHistogram
Dim pHistogram As IHistogram
Dim frqs As Variant, xVals As Variant
Dim i As Integer
Set pFClass = pFeatLayer.FeatureClass
Set pFCursor = pFClass.Search(Nothing, False)
Set pFeature = pFCursor.NextFeature
Set pTable = pFClass
'Set pClassifyGEN = New Quantile
Select Case sClassification
Case "Equal Interval"
Set pClassifyGEN = New EqualInterval
Case "Natual Breaks"
Set pClassifyGEN = New NaturalBreaks
Case "Quantile"
Case "Standard Deviation"
Set pClassifyGEN = New StandardDeviation
End Select
'Set pClassifyGEN = New EqualInterval
Set pTableHistogram = New TableHistogram
Set pHistogram = pTableHistogram
pTableHistogram.Field = sValFieldName
' matches renderer field
Set pTableHistogram.Table = pTable
pHistogram.GetHistogram xVals, frqs
pClassifyGEN.Classify xVals, frqs, lNClass
' use "iNClass" number of classes
GenerateClassBreaks = pClassifyGEN.ClassBreaks
GoTo Endproc
ErrorHandler:
MsgBox Err.Description, vbInformation, "GenerateClassBreaks"
Endproc:
Set pFClass = Nothing
Set pFeature = Nothing
Set pFCursor = Nothing
Set pTable = Nothing
Set pClassifyGEN = Nothing
Set pTableHistogram = Nothing
Set pHistogram = Nothing
End Function
Regards
