ArcGIS Pro Hi, I have a script which is meant to export 10 or so Map Series pages to seperate PDFs. PDFs are to be named by page number.
However, the script runs through to the end without exporting any PDFs. All I get is the two print commands upon completion.
-MapSeries is enabled in the Project.
-I have all appropriate permissions.
Any ideas? I used the example script from: MapSeries—ArcPy | ArcGIS Desktop to help me.
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> sys
relpath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>argv<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
p <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"C:\\Users\\Tom\\Documents\\GIS_Tasks\\General_tasker\\General_tasker.aprx"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"project located"</SPAN><SPAN class="punctuation token">)</SPAN>
l <SPAN class="operator token">=</SPAN> p<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"layouts listed"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="operator token">not</SPAN> l<SPAN class="punctuation token">.</SPAN>mapSeries <SPAN class="keyword token">is</SPAN> None<SPAN class="punctuation token">:</SPAN>
ms <SPAN class="operator token">=</SPAN> l<SPAN class="punctuation token">.</SPAN>mapSeries
<SPAN class="keyword token">if</SPAN> ms<SPAN class="punctuation token">.</SPAN>enabled<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> pageNum <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> ms<SPAN class="punctuation token">.</SPAN>pageCount <SPAN class="operator token">+</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
ms<SPAN class="punctuation token">.</SPAN>currentPageNumber <SPAN class="operator token">=</SPAN> pageNum
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Exporting page {0} of {1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>currentPageNumber<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>pageCount<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
l<SPAN class="punctuation token">.</SPAN>exportToPDF<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"C:\\Users\\Tom\\Dropbox\\Production\\Internal Automation\\Assess_automation\\Current_assess_site_plans\\Assess_{0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>ms<SPAN class="punctuation token">.</SPAN>currentPageNumber<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">".pdf"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
