I have a custom PrintTask which I created following the Advanced Printing Tutorial. When I execute the PrintTask, the pdf is created and resides in the arcgisjobs folder on my GIS Server. I can open the pdf manually but I can not get it to open using window.open(result.url). The result url is null. If I examine the result object, I see that it is an esri DataFile with a url property that is null.Has anyone else created a custom PrintTask with different results? How do I get the path and file name returned when the print task completes if the result object does not have the url?Here is my code:function advancedPrint(printScale) { require(["esri/SpatialReference", "esri/tasks/PrintTask", "esri/tasks/PrintTemplate", "esri/tasks/PrintParameters"], function (SpatialReference, PrintTask, PrintTemplate, PrintParameters) { var printURL = dataLink + "/Test/AdvancedPrint/GPServer/AdvancedPrint" var printTask = new PrintTask(printURL, { async: true }); var formatOpt = getFormat(); var printLayout = getLayout(); var sr = new SpatialReference(102748); var printParams = new PrintParameters(); printParams.map = map; printParams.outSpatialReference = sr; printParams.extraParameters = { mapExtent: map.extent, printToScale: printScale }; var printTemplate = new PrintTemplate(); printTemplate.format = formatOpt; printTemplate.layout = printLayout; // "Letter ANSI A Landscape"; printTemplate.preserveScale = false; printTemplate.layoutOptions = { titleText: dijit.byId("txtPrintTitle").value, authorText: dijit.byId("txtPrintAuthor").value, copyrightText: "Copyright 2014", scalebarUnit: "Miles" }; printParams.template = printTemplate; // Progress bar var i = 0; var progressBar = dijit.byId("progressBar"); var progressGo = setInterval(function () { progressBar.set("value", i++ % 100); }, 300); setTimeout(function () { clearInterval(progressGo); }, 10000); // Execute Print Task printTask.execute(printParams, printComplete); }); } function printComplete(result) { window.open(result.url); var progressBar = dijit.byId("progressBar"); progressBar.label = "Print Complete"; }Thanks,Janice.
