I want to write a small tool, which insert some data into an MS-Access database (.mdb). But i have a problem to initialize the cursor.
The Code is very simple :
strOutputPath = r"I:\Data\Test.mdb\FS_BASEMAP\FCL_B_COVERSHEET_A"
icur = arcpy.InsertCursor(strOutputPath)
There is some more code but it stoped at this point and I get this error message:
File "I:\Skript\AddFeatureSkript.py", line 70, in <module>
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\__init__.py", line 1214, in InsertCursor
return gp.insertCursor(dataset, spatial_reference)
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 369, in insertCursor
self._gp.InsertCursor(*gp_fixargs(args, True)))
RuntimeError: ERROR 999999: Fehler beim Ausführen der Funktion.
COM-Komponente der Objektklassenerweiterung konnte nicht erstellt werden. [FCL_B_COVERSHEET_A]
The error message is in german so I translate it:
ERROR 999999: Error when executing the function.
COM component object class extension could not be created. [FCL_B_COVERSHEET_A]
I don't know what the problem is, so hopefully some can help me.
Thanks, Regards
