Hello, I've been looking into the Feature Layer (Geodatabase) QML example and I've tried to just do the same with a sqlite spatialite database, to no avail
Is it possible to do so?
I have a spatial table with the following structure, created from SQlite:
CREATE TABLE "furos" (
"OBJECTID" integer NOT NULL PRIMARY KEY AUTOINCREMENT,
"SHAPE" MULTIPOINT,
"ID_FURO" integer NOT NULL,
"FURO_TX_NOME" text(255),
"FURO_VL_MC" text(50),
"FURO_VL_LAM_DAGUA" text(50),
"FURO_VL_PROF_FINAL" text(50),
"X_SIRGAS" text(50),
"Y_SIRGAS" text(50),
"X_CGS" text(50),
"Y_CGS" text(50),
"GUID" TEXT(255),
"DATA_IMPORTACAO" DATE
And I've tried loading the database file by basically doing the same code from the geodatabase example:
Map { id: map
BasemapStreetsVector {} FeatureLayer { featureTable: gdb.geodatabaseFeatureTablesByTableName["furos"] ?
gdb.geodatabaseFeatureTablesByTableName["furos"] :
null
Geodatabase { id: gdb
path: pathName
onErrorChanged: errorMessage = error.message;
onLoadStatusChanged: { console.log(dataPath);
console.log(errorMessage);
if (loadStatus !== Enums.LoadStatusLoaded)
return;
mapView.setViewpointCenterAndScale(fullExtent.center, 80000);
Unfortunately, nothing happens. I receive these three errors from Qt:
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in runtimecore!RT_UtilityTraversability_fromJSON
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in runtimecore!ESRI_CopyProtect_GetInstallDir
Exception at 0x7ffd59bfa799, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in ntdll!RtlCaptureContext
Is it possible to load only geodatabases created from ArcMap or something similar? I can open these kind of files in the SQLite Browser so I thought the format was basically the same.
