Trying to Publish Service that will be able to Sync when added to ArcGIS online application
I read that the below had to be done.
- Set as Versioned
- Add Global ID
- Enable Archiving
- I did the above and can view in ArcMap.
- I then go to publish as a Feature service.
- In Capabilities under Feature Access I check the Sync checkbox
- I do an analyze and get an error
Error Code: 00191
Error Description: Invalid feature service capabilities configuration for sync
Error Name: Layers
Error Type: Data Frame
Error Data Frame: Layers
Any thoughts?
