so i am liking query layers a lot so far in playing with them!my current question regards how keep the order i specify for the fields.here is a query i am working with as an example:SELECT sde2.sde.STREETCL_ARC.OBJECTID, sde2.sde.STREETCL_ARC.Shape, sde2.sde.STREETCL_ARC.SEG_ID, LTRIM(sde2.sde.STREETCL_ARC.PRE_DIR +' ' + sde2.sde.STREETCL_ARC.ST_NAME +' ' + sde2.sde.STREETCL_ARC.ST_TYPE) AS STREETNAME, sde2.sde.STREETCL_ARC.ST_CODE, sde2.sde.STREETCL_ARC.ONEWAY, sde2.sde.STREETCL_ARC.CLASS, sde2.sde.BIKE_NETWORK_TBL_NEW.TYPE FROM sde2.sde.STREETCL_ARC RIGHT OUTER JOIN sde2.sde.BIKE_NETWORK_TBL_NEW ON sde2.sde.STREETCL_ARC.seg_id = sde2.sde.BIKE_NETWORK_TBL_NEW.SEG_ID
this makes a nice query layer with all the info i want HOWEVER if you notice i concatinate the field STREETNAME from a few fields. whenever the query layer is displayed this field shows up last. is there anyway to preserve the order i specify above (keep STREETNAME as the 4th column between SEG_ID and ST_CODE)?thanks,max
