I'm not having any success sorting an arcpy.da.SearchCursor by the SHAPE Area values. No errors but it doesn't sort descending from my testing.
Anyone able to confirm this or offer a suggestion?
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>clip_fc<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@AREA'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'POLYGON_NM'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>sql_clause<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'ORDER BY SHAPE.STArea() DESC'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> clipcur<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> cliprow <SPAN class="keyword token">in</SPAN> clipcur<SPAN class="punctuation token">:</SPAN>
areaval <SPAN class="operator token">=</SPAN> cliprow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
