First of all: I'm using ArcGIS SDK for .Net (in WPF).
I've asked this question some time ago at Geographic Information Systems Stack Exchange , but got no answers ... one more shot.
I'm having the following issue:
Suppose I have a Map object and 2 base layers (a world map and a street map). A world map doesn't let us view the map too closely. The street map allows us to view as close as we want (almost). So, they have different scale parameters. Now, if I load the world layer first, like this (pseudocode):
<SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Insert</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="lit" style="color: #953838;">0</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">WorldLayer</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN>
and then switch layers:
<SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Remove</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="str" style="color: #800000;">"WorldLayer"</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;">
map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Insert</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="lit" style="color: #953838;">0</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">Streetlayer</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN>
The map doesn't allow me to get closer than a WorldLayer allowed. SO, actually, I can't view a street view normally.
BUT, if I load a detailed map first:
<SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Insert</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="lit" style="color: #953838;">0</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">Streetlayer</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN>
<SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Remove</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="str" style="color: #800000;">"Streetlayer"</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;"> map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Layers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="typ" style="color: #2b91af;">Insert</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="lit" style="color: #953838;">0</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">WorldLayer</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN>
In this case I can freely view trees near my home And even if I switch back, the WorldLayer would allow me to get closer than it allowed before.
I suppose there should be a way to update a map, to renew scale/zoom parameters for a new set of layers. Is anyone aware of a way to achieve that?
