Hey everyone,I am trying to:- Set a search cursor through table 1 which contains 2 fields. S_RANK and DESCRIPTION
- within the first loop, I am cursor searching through Table 2 which contains 2 fields. G_RANK and DESCRIPTION
- Updating a cursor on table 3 which contains 2 fields. ANHIC_RANK and DESCRIPTION
In the update cursor, I want to populate ANHIC_RANKING field in table 3 with a concatenation of S_RANK + G_RANK from the first. I want to update the DESCRIPTION field in table 3 with a concatenation of the 2 DESCRIPTION fields from the first 2 tables (i.e. DESCRIPTION + " + " + DESCRIPTION)The print statements in the first 2 loops print out fine, it's the update cursor that doesn't seem to update. Any suggestions?Thanks,Mike
import arcpy
from arcpy import env
env.workspace = r"Z:\IOR\2012\2012_Geodatabase_UTM\DOMAIN_CODE_TABLES.gdb"
for x in arcpy.SearchCursor("ANHIC_RANK_S"):
print x.S_RANK
print x.DESCRIPTION
for y in arcpy.SearchCursor("ANHIC_RANK_G"):
print y.G_RANK
print y.DESCRIPTION
with arcpy.da.UpdateCursor("ANHIC_RANKING_FINAL", ["ANHIC_RANKING", "DESCRIPTION"]) as cursor:
for row in cursor:
row.ANHIC_RANKING = x.S_RANK + y.G_RANK
row.DESCRIPTION = x.DESCRIPTION + " + " + y.DESCRIPTION
c.updateRow(row)
