I'm creating 3 feature layers in one function. I'd like to return them from the function in a list, but as I expected, their type in the list is just string. I know I can save them out as a lyr file, but trying to avoid that if possible. Maybe they go out of scope when the function ends? Thanks.
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">makeFeatureLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""
Make feature layers from Annotation, Polygon and Points features
"""</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\nCreating feature layers"</SPAN><SPAN class="punctuation token">)</SPAN>
anno <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Annotation'</SPAN>
pt <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Point'</SPAN>
poly <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Polygon'</SPAN>
anno_path <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>ds_path<SPAN class="punctuation token">,</SPAN> anno<SPAN class="punctuation token">)</SPAN>
pt_path <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>ds_path<SPAN class="punctuation token">,</SPAN> pt<SPAN class="punctuation token">)</SPAN>
poly_path <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>ds_path<SPAN class="punctuation token">,</SPAN> poly<SPAN class="punctuation token">)</SPAN>
fc_dict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
fc_dict<SPAN class="punctuation token">[</SPAN>anno<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> anno_path
fc_dict<SPAN class="punctuation token">[</SPAN>pt<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> pt_path
fc_dict<SPAN class="punctuation token">[</SPAN>poly<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> poly_path
fc_list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> k<SPAN class="punctuation token">,</SPAN> v <SPAN class="keyword token">in</SPAN> fc_dict<SPAN class="punctuation token">.</SPAN>iteritems<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
lyr_name <SPAN class="operator token">=</SPAN> k <SPAN class="operator token">+</SPAN> <SPAN class="string token">'_lyr'</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>v<SPAN class="punctuation token">,</SPAN> lyr_name<SPAN class="punctuation token">)</SPAN>
fc_list<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>lyr_name<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN> Exception <SPAN class="keyword token">as</SPAN> e<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\nError: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetMessages<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> fc_list<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\nType of fc: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>type<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
