I am having this issue when I am using BG geoprocessing 64 bit
File "<pyshell#0>", line 1, in <module>
import arcpy
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\__init__.py", line 21, in <module>
from arcpy.geoprocessing import gp
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from _base import *
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geoprocessing\_base.py", line 598, in <module>
env = GPEnvironments(gp)
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geoprocessing\_base.py", line 595, in GPEnvironments
return GPEnvironment(geoprocessor)
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geoprocessing\_base.py", line 551, in __init__
self._refresh()
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\geoprocessing\_base.py", line 553, in _refresh
envset = (set(env for env in self._gp.listEnvironments()))
RuntimeError: NotInitialized
not sure how I can solve this issue
on the other hand the 32 bit is working without any problems but at the same time I cannot use the 32 bit for the time being. therefore, I installed the BG geoprocessing 64 bit
