I recently upgraded from ArcGIS Javascript 4.8 to 4.15, and it broke the generation of my client-side Feature Layers.
I was wondering what was causing this code to display the improper symbol. I want a solid grey polygon, but it gives me a polygon with no fill for some reason.
I also want the proper attributes being shown up in the popupTemplate but it says undefined for both fields.
Notes about my code. Before the update, I defined the symbol and popupTemplate for the graphic and defined the renderer as such:
renderer: {
type: "simple"
}But that didn't work so I've been tinkering trying to see where the issue is.
Debugging on both FireFox and Chrome.
Below is my code:
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>Testing Layer Issues</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.15/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/geometry/Polygon",
"esri/Graphic"
], function(Map, MapView, FeatureLayer, Polygon, Graphic) {
var map = new Map({
basemap: "topo-vector"
var view = new MapView({
container: "viewDiv",
map: map,
center: [-115, 54.5],
zoom: 6
var rings = [[-12501210, 8357231],
[-12490077, 8357231],
[-12490077, 8367861],
[-12467811, 8367861],
[-12467811, 8389121],
[-12478944, 8389121],
[-12478944, 8378491],
[-12501210, 8378491],
var greyPolygonAtt = {
Name: "No Road Infrastructure",
Message: "This area has insufficient road infrastructure for transportation"
var greyPolygonGraphic = new Graphic({
geometry: new Polygon({
hasZ: false,
hasM: false,
rings: rings,
spatialReference: 102100
attributes: greyPolygonAtt,
var fields = [{
alias: "OBJECTID",
type: "oid"
var greyGraphics = [ greyPolygonGraphics ];
var greyLayer = new FeatureLayer({
source: greyGraphics,
fields: fields, // required
objectIdField: "OBJECTID",
geometryType: "polygon",
popupTemplate: {
title: "{Name}",
content: "{Message}"
renderer: {
type: "simple",
symbol: {
type: "simple-fill",
color: [150, 150, 150, 1],
outline: {
width: "1px"
style: "solid"
map.add(greyLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
