Background: I'm helping out a friend with their digital field recording conversion. They have a Archer unit running ArcPad and post processing using EFFIGIS/EZSurv. For the past 12 months they have been setting up shapefiles to transfer back and forth. They wanted to step it up with dropdowns etc so I suggested that they use feature classes as they should port over via .axf. Transfer to the device worked. Parking lot test worked (ie dropdowns were good). I am remote to their location so I don't have hands on to work with it.
Problem: When the parking lot test came back in, they seem to have post processed fine, however when they go to Get Data From, it comes up with an error. "The following ArcPad AXF files were skipped: Did not contain a transaction log: C:\Users\[name]\AppData\Local\Microsoft\Windows\INetCache[cut off]"
They told me the workflow they were using this time was the same as when they did when it was shapefiles. So I'm assuming that there is a workspace environment issue or the data itself is getting corrupted when they try to post process it.
Any ideas?
