i have developed a model to download a layer from arcgis online every week and overwrite the GDB with the previous weeks information. I was then manually feeding this into a project and exporting a Map series for a weekly report. i decided to also try and automate this process so i could have reports generated automatically every week. i am a beginner at python and am self thought so please bear with me.
my script is as follows which i developed in a notebook
#!/usr/bin/env python
# coding: utf-8
# In[98]:
import arcpy
import os
import sys
aprx = arcpy.mp.ArcGISProject("CURRENT")
default = aprx.defaultGeodatabase
default
# In[116]:
import os
directory = 'C:\\Usersxxxxxxxxxxxxxx'
for filename in os.listdir(directory):
if filename.endswith(".gdb"):
print(directory+filename)
newGDB = directory+filename
newGDB
# In[117]:
newGDB
# In[101]:
aprx = arcpy.mp.ArcGISProject(r"C:\Users\xyz.aprx")
default
# In[60]:
import arcpy
m = aprx.listMaps("Map")[0]
lyr = m.listLayers("Assignments")[0]
lyr.connectionProperties
# In[102]:
newCP={'dataset': 'Assignments',
'workspace_factory': 'File Geodatabase',
'connection_info': {'database': newGDB}}
newCP
# In[103]:
lyr.updateConnectionProperties(lyr.connectionProperties, newCP)
# In[104]:
# In[105]:
tableAtt=m.listTables("Assignments__ATTACH")[0]
tableAtt.connectionProperties
# In[106]:
tableAtt.updateConnectionProperties(tableAtt.connectionProperties, newCP)
# In[107]:
# In[108]:
tableGDBService=m.listTables("GDB_ServiceItems")[0]
tableGDBService.connectionProperties
# In[109]:
tableGDBService.updateConnectionProperties(tableGDBService.connectionProperties, newCP)
# In[110]:
# In[111]:
aprx.save()
# In[112]:
l = aprx.listLayouts()[0]
l
# In[113]:
import os
import sys
import datetime
from datetime import datetime
relpath = os.path.dirname(sys.argv[0])
printpath = r"T:\xyz"
str=current_time = datetime.today().strftime('%d-%m-%Y')
relpath
# In[114]:
aprx = arcpy.mp.ArcGISProject(r"xyz.aprx")
if not l.mapSeries is None:
ms = l.mapSeries
if ms.enabled:
ms = l.mapSeries
pagecount = ms.pageCount
indexLyr = ms.indexLayer
pagecount
# In[115]:
ms.exportToPDF(printpath+str,embed_fonts = True,resolution=400,georef_info=False,image_quality='FASTER',page_range_type = 'ALL',jpeg_compression_quality=25,output_as_image=False,layers_attributes='NONE',image_compression='ADAPTIVE')
# In[ ]:
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>it had work when i run it through the notebook but when i run it in a model in order to schedule it i am getting the following error.
File "C:\Users\xxxxxxxxxxxxxxxxx.tbx#ReplaceDSandPDF_ExcavationReports.py", line 50, in <module>
IndexError: list index out of range
Failed to execute (Replace DS and PDF).
Any tips on where i am going wrong or even how to improve on my process are greatly appreciated.
