This print widget is blocked before creating an output. The combobox properly retrieves the print task url, but the console shows "TypeError: b is undefined" for http://js.arcgis.com/3.17/esri/tasks/PrintTask.js:25:13.
Map is created in Map.js
var map;
var baseMapLayerWorld;
require([
"esri/map", "esri/dijit/Search", "esri/layers/ArcGISDynamicMapServiceLayer","esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"
], function (Map, Search, DynamicMapServiceLayer, FeatureLayer, InfoTemplate) {
baseMapLayerWorld = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer");
map = new Map("map", {
center: [-150, -17], // lon, lat
zoom: 8
map.addLayers([baseMapLayerWorld);
});The print widget is implemented in Print.js:
var app = {};
require([
"esri/map", "esri/layers/FeatureLayer",
"esri/dijit/Print", "esri/tasks/PrintTemplate",
"esri/request", "esri/config",
"dojo/_base/array", "dojo/dom", "dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
Map, FeatureLayer,
Print, PrintTemplate,
esriRequest, esriConfig,
arrayUtils, dom, parser
parser.parse();
app.printUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
esriConfig.defaults.io.proxyUrl = "http://our-server/Java/proxy.jsp";
// get print templates from the export web map task
var printInfo = esriRequest({
"url": app.printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length === 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = arrayUtils.map(templateNames, function(ch) {
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: Esri's JS API Team",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Pool Permits",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
app.printer = new Print({
"map": app.map,
"templates": templates,
url: app.printUrl
}, dom.byId("print_button"));
app.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
});They come together in the index.html:
<!DOCTYPE html>
<html dir="ltr">
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/dojox/layout/resources/ExpandoPane.css">
<link rel="stylesheet" href="css/widget_styles.css">
<script src="https://js.arcgis.com/3.17/"></script>
<script type="text/javascript">
dojo.require("dojox.layout.ExpandoPane");
</script>
<script src="js/Map.js"></script>
<script src="js/Legend.js"></script>
<script src="js/Search.js"></script>
<script src="js/Print.js"></script>
</head>
<body class="claro">
<div id="content"
data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:true"
style="width: 100%; height: 100%; margin: 0;">
<div id="rightPane"
data-dojo-type="dojox/layout/ExpandoPane"
data-dojo-props="region:'right',title:'Widgets',startExpanded:false">
<div data-dojo-type="dijit/layout/AccordionContainer">
<div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
data-dojo-props="title:'Légende', selected:true">
<div id="legendDiv"></div>
</div>
data-dojo-props="title:'Pane 2'">
</div>
</div>
</div>
<div id="map"
data-dojo-props="region:'center'"
style="overflow: hidden;width: 100%; height: 100%; margin: 0;">
<div id="feedback" class="shadow">
<h3>
Print Templates Created from Info Returned by the Print Service using
<a href="https://developers.arcgis.com/javascript/3/jsapi/esri.request-amd.html">esri.request</a>
</h3>
<div id="info">
<div id="note">
Note: This sample uses an ArcGIS Server version 10.1 export web map task.
</div>
<div id="print_button"></div>
<div id="info">
<a href="https://developers.arcgis.com/javascript/3/jsapi/printtemplate.html">Print templates</a> are generated
from the Export Web Map Task's <a href="https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task">Layout_Template parameter</a>. This info is retrieved from the service
using <a href="https://developers.arcgis.com/javascript/3/jsapi/esri.request-amd.html">esri.request</a>.
</div>
</div>
</div>
</div>
<div id="search"></div>
</div>
</body>
</html>
