Hi All,I am working on a project in ArcPad 8 SP3.I have a Shapefile with to fields- UserNumber (Long Integer)
- UserText3 (Text Field)
Below is my Code that i have created to autogenerate a Unique ID and my Text_box that it relates to will store that value that is returned to UserNumber. How would I go about adding that value directly to the Attribute table for UserText3?
Sub InitialiseGPSID
'Do any form initialization in this sub
Dim objEFPageOneControls, objEditForm
Set objEditForm = ThisEvent.Object
Set objEFPageOneControls = objEditForm.Pages("PAGE1").Controls
'Initialization for form in any mode
'Disable the GPS ID edit box
objEFPageOneControls("txt_GPSID").Enabled = False
'Initialization for form when adding new records
If objEditForm.Mode = 3 Then ' Mode 3 is used when creating a new feature.
'Get the Fence Points layer's recordset (to pass into the ReturnNextID function)
Dim objUniqueID
Set objUniqueID = Layer.Records
if ReturnNextID (objUniqueID, "USERNUMBER") = 1 then
'Update the Tree ID
objEFPageOneControls("txt_GPSID").Value = ReturnNextID (objUniqueID, "USERNUMBER") + 10000
else
end if
End If
'Free objects
Set objEFPageOneControls = Nothing
Set objEditForm = Nothing
Set objUniqueID = Nothing
End Sub
'Also write the function ReturnNextID that is called by InitializeForm.
Function ReturnNextID (objRS, strFieldName)
Dim intMax
'Get the first record
objRS.MoveFirst
'Initialize the max value to the first record
intMax = CInt(objRS.Fields(strFieldName).Value)
'Loop through the records, updating the max value if necessary
Dim intCurrVal
While Not objRS.EOF
intCurrVal = CInt(objRS.Fields(strFieldName).Value)
If (intCurrVal > intMax) Then
intMax = intCurrVal
End If
objRS.MoveNext
Wend
ReturnNextID = intMax + 1
End Function
