I have a webmap which I use in a mobile app with Xamarin Forms, ArcGIS and Prism .NET Runtime 100.5.
Often my MapView is loaded (Map.LoadStatus → Loaded) but the draw status remains in progress (DrawStatus → InProgress), (the application show a blank grid with the attribution) and freeze the UI. Sometimes all works fine (Map.LoadStatus → Loaded & DrawStatus → Completed). The issue is independent of the web connection and come from the mapView.
There are no other threads I invoke in my code that could freeze the UI.
The problem persists despite different implementations. I followed the following sample: Display a map—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
XAML :
<viewmodels:MapViewViewModel x:Name="mapView" />
MapViewViewModel.cs :
public class MapViewViewModel : MapView, INotifyPropertyChanged
public MapViewViewModel()
const string WebMapId = "..." ;
DrawStatusChanged += OnDrawStatusChanged;
Device.BeginInvokeOnMainThread(async () =>
var portal = await ArcGISPortal.CreateAsync(new Uri("http://www.arcgis.com/sharing/rest"));
var portalItem = await PortalItem.CreateAsync(portal, WebMapId);
Map = new Esri.ArcGISRuntime.Mapping.Map(portalItem);
await Map.LoadAsync();
private async void OnDrawStatusChanged(object sender, DrawStatusChangedEventArgs e)
Console.WriteLine(e.Status.ToString());
