Original User: luke.kaimHi Everyone,I am trying to write python code to detect if there is overlapping polygon from two feature classes. The goal of this code is to get overlapping polygons and there area. I start by trying to get the area of the polygons themselves. This I am trying to do using arcpy.geometry. Next I want to use the overlap geometry operation in 10.1. This is a boolean operation that will speed up the intersection command later. Then I do the intersection and the symmetric difference. The end goal is to get polygon overlap/difference. I think I have a few bugs in my code, but I am struggling to get the logic and the syntax correct. I tried to model my code off of this thread: http://forums.arcgis.com/threads/60968-area-of-overlap-between-polygons-in-two-different-feature-classes?highlight=arcpy.Geometry%28%29 .Any help would be greatly appreciated.Code:def main():
try:
import arcpy, sys, traceback, os, string, locale
from arcpy import env
env.workspace =r"C:\Users\Luke Kaim\Documents\University of Maine\Fall_2012\Volunteer Geographic Information\simalar"
VGIFile = r"C:\Users\Luke Kaim\Documents\University of Maine\Fall_2012\Volunteer Geographic Information\simalar\polygon.shp"
VGIFileShapeName = arcpy.Describe(VGIFile).ShapeFieldName
VGIRows = arcpy.SearchCursor(VGIFile)
GNIS_FC = r"C:\Users\Luke Kaim\Documents\University of Maine\Fall_2012\Volunteer Geographic Information\simalar\GNIS.shp"
GNIS_FCShapeName = arcpy.Describe(GNIS_FC).ShapeFieldName
GNIS_FCRows = arcpy.SearchCursor(GNIS_FC)
#Create an empty Geometry object
g = arcpy.Geometry()
area=0
# get Geometry of every VGI polygon. Then get the area of each polygon
for VGIFileShapeName in VGIRows:
feat = VGIFileShapeName.getValue(shapeName)
area += feat.area
print area
area=0
# get Geometry of every GNIS polygon. Then get the area of each polygon
for GNIS_FCShapeName in GNIS_FCRows:
feat = GNIS_FCShapeName.getValue(shapeName)
area += feat.area
print area
for VGIRow in VGIRows:
VGIGEOM = VGIRow.getValue(VGIFileShapeName)
GNIS_Rows = arcpy.SearchCursor(GNIS_FC)
for GNIS_Row in GNIS_Rows
GNIS_Geom = GNIS_Row.getValue(GNIS_FCShapeName)
if GNIS_Geom.overlaps(VGIGEOM):
arcpy.Intersect_analysis([GNIS_Geom,VGIGEOM],"in_memory/Intersection")
arcpy.SymDiff_analysis([GNIS_Geom,VGIGEOM],"in_memory/SymDiff")
intersectionRows = arcpy.SearchCursor("in_memory/Intersection")
for intersectionRow in intersectionRows:
intersectionArea = intersectionRow.Shape.area
print "Overlap Area: " + str(intersectionArea)
intersectionRows2 = arcpy.SearchCursor("in_memory/"in_memory/SymDiff"")
for intersectionRow1 in intersectionRows2:
intersectionArea2 = intersectionRow1.Shape.area
print "Overlap Area :in_memory/SymDiff " + str(intersectionArea2)
del VGIRows, GNIS_FCRows,GNIS_Rows
Thank you,Luke Kaim Thank youLuke Kaim (SIE)Lucas.Kaim@maine.edu(914)263-7866"Don�??t complain. Just work harder" (Randy Pausch).
